• 07.10.2026, 22:26
Falcon3
Aquaero 5 cannot be detected by Aquasuite 2012
Mittwoch, 19. Dezember 2012, 10:20
Please help - ;( ........
I did the following today
1. down-loaded Aquasuite 2012
2. Connected a USB cable to the A5 to NZXT USB hub - hub to USB on MB.
3. Connected molex power A5 AND 3 x PA2 Ultra.
4. Connected USB cable to the first PA2 and onto NZXT hub.
booted up computer - changed time/date/lang on A5 using the remote pad (nice).
opened up Aquasuite and fiddled around the pages looking for the PA2 hardware - as instructed in a attempt to change the ID - WITH NO LUCK! - I then accidently deleted the A5 PAGE!!!!!!!!
then rebooted computer including at the base (so that the A5 Powered down) - and with no luck - I uninstalled Aquasuite and reinstalled - still A5 was not avbl , I even tried installling and running a older
version of the Software .
Read thru lots of previous threads - and in one of them there is a question "is the A5 showing up under Devices and Printer and yes! and so is the power adjust 2 with the ! in yellow.
what have I done wrong, :?:
Additionaly ; the A5 still has power to it when the computer is switched off! - is this normal?
Mittwoch, 19. Dezember 2012, 10:43
Maybe you could post a screenshot of your aquasuite?
At the moment it sounds like your aquaero is not detected by Windows at all. The page that you have deleted is only an overview page which has nothing to do with the regular aquaero menu.
It is normal that the aquaero is still running when you shut down the PC. It is powered by USB when the PC is turned off.
