• 29.11.2026, 07:31
dxb750
2 tubemeter USB fill level sensor >>> Problem!!?
Samstag, 5. Januar 2013, 19:02
I have two tubemeter USB and I connect it like this :
*There Internal USB Expansion between the tubemeter and the motherboard.. http://www.amazon.com/gp/product/B0031ESKJA
Often all the tubemeters do not work, and sometimes only one tubemeter working with aquasuite !
Is it one previously faced the same problem??
Thanks,
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »dxb750« (5. Januar 2013, 19:29)
dxb750
Sonntag, 6. Januar 2013, 19:18
I tried to connect it directly to the board, but the same problem!
:wacko:
LarryWill729
Montag, 7. Januar 2013, 02:02
I think the problem is that the tubemeters might not have a changeable address like the PA2 and mps.
One other user has two tubemeters installed and if I remember correctly he connected one via USB and the other is connected to the low speed Aquabus connector. This requires a four wire connector and there is not quite enough room to use a five pin USB connector. So use a four wire Aquabus cable and you should be fine.
AMD FX-8150 OctoCore O.C. 18% to 4.2 GHz on ASUS M5A99X EVO with 16 GB Corsair Dominator W. C. RAM, 2 nVIDIA Geforce 560TI W.C. in SLI, six Western Digital drives for a total of 4.07 TBytes, AquaComputer Aquero 5 Pro, AquaComputer D5 pump, Multiswitch USB, tubemeter and Kyros CPU block. Two coolant loops,CPU & SLI, MB, RAM and AQ5, with two flow meters. Running Windows 7 Professional 64, and using Open Hardware Monitor v0.5.1Beta Aquasuite B16 hardware temps.
dxb750
Dienstag, 8. Januar 2013, 11:57
Thank U very much Larry :)
tpb211
Freitag, 18. Januar 2013, 07:35
Was your probles resolved? I too am running the same tube meter and running into all kinds of difficulties. sometimes the LED blinks on it, sometimes it does not, always reports 90% lvl have never seen it budge by even a single percentage. I am wondering if my unit is buggered and not relaiable. Looking for more advice specifidcally on when the led on the tube meter should be flashing and for how long.
