• 09.10.2026, 09:48
Whatts
Aquaero Waterblock: metal screws?
Freitag, 11. Januar 2013, 09:13
Hi all,
I received my Aquaero 5 LT and waterblock yesterday, but the waterblock came with 3 metal screws only.
Is it supposed to be mounted with these metal screws, without spacers or anything to isolate it from the PCB?
The reviews I had read all mentioned plastic type screws, but that's not what was in my package.
Greetz,
Tom
mandrix
Freitag, 11. Januar 2013, 11:58
Yes, the metal screws won't contact any part of the pcb that will cause problems. Be careful when you assemble it and you should be OK.
Whatts
Freitag, 11. Januar 2013, 13:02
OK, thanks for the info.
I have some nylon washers on order, I'll give it a good look when I'm starting my build.
