• 05.10.2026, 13:52
arzaman
Aquaero 5 PWM output frequency change
Donnerstag, 17. Januar 2013, 23:15
I'm new on the forum and this is my first post since I'm evaluating Aquaero 5 controller for a cooling application
I would like to control a peltier (TEC) chiller using the PWM output and an H-bridge circuit for power adjust.
Varying the duty cycle of PWM from 0 to 100% I would like to drive the TEC power and possibly reverting cold/hot side
The key point is that as far as I understand PWM applied to Peltier cells should be low frequency..round 2-3 Khz
Instead from specification Aquareo PWM outputs have
16Khz frequency
Is there any way to change/set the PWM frequency via GUI or software configuration ?
sure of your support
regards
Davide
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »arzaman« (17. Januar 2013, 23:18)
arzaman
any help
Sonntag, 20. Januar 2013, 18:38
Hi All
any chance to understand if I can tweak the PWM output frequency (GUI or SW config) ?
regards
Davide
mandrix
Montag, 21. Januar 2013, 15:07
My understanding is the PWM frequency is fixed. The only changes available through the Aquasuite software are for % power output.
Dienstag, 22. Januar 2013, 07:20
The frequency is fixed, you can only set the duty cycle.
arzaman
Dienstag, 22. Januar 2013, 09:46
thank you for the info... I will try to understand if I can drive a Peltier Cell with 16khz frequency
One more thing still on the two PWM output...may I connect the output to a input temperature sensor and a control algorithm (PID) like other fan output ?
regards
Davide
