• 12.10.2026, 09:11
_KaszpiR_
Need advice - connecting mps flow 200 and D5 pump to aquacomputer 5 pro
Mittwoch, 23. Januar 2013, 22:29
I'd like to connect mps flow 200 and (future) D5 USB pump to the aquaero 5 pro:
mps flow 200 - http://shop.aquacomputer.de/product_info…roducts_id=2899
D5 pump with USB and aquabus interface http://shop.aquacomputer.de/product_info…roducts_id=2901
I want to use 4 pin cables for that - http://shop.aquacomputer.de/product_info…roducts_id=2846 - so that pump and mps will be connected to the aquaero device directly, to avoid later connections with USB cables.
If I'm not mistaken:
the mps flow 200 is 'low speed' so it should be connected to aquabus 1
the D5 pump is 'high speed' so it should be connected to aquabus 2.
Looking forward for the feedback.
_KaszpiR_
Donnerstag, 24. Januar 2013, 20:15
Ah, that means I need 4-pin Y splitter and 2x 4pin aquabus cables. and it should be connected to aquabus 2 via Y splitter.
