• 29.09.2026, 10:31
Buckey
Aquasuite 2012
Montag, 25. Februar 2013, 02:47
How do you do a clean install of Aquasuite 2012 - 6 64 bit?
mandrix
Dienstag, 26. Februar 2013, 14:44
Delete the Program Data folder for Aquasuite 2012 after uninstalling the software. Do not use any saved settings.
Buckey
Donnerstag, 28. Februar 2013, 04:34
I deleted the aquasuite 2012 folder and it still has some of the previous setting. I even chose no for using previous settings during the install too. I think I am going to try running this stuff on a completely different computer that has never had any of it before. Will the results be the same?
LarryWill729
Freitag, 1. März 2013, 20:41
If you saved settings to the AQ5 from Aquasuite2012, wipe the hard drive and install a fresh OS, and then install AS2012 again, the Aquasuite will "Read" the AQ5 and restore the settings. I just did this with my wifes computer and EVERYTHING carried to the fresh install from the old.
If you want a CLEAN install with nothing carried forwarde, you must do a firmware reset of the AQ5 before re installing the AS2012.
AMD FX-8150 OctoCore O.C. 18% to 4.2 GHz on ASUS M5A99X EVO with 16 GB Corsair Dominator W. C. RAM, 2 nVIDIA Geforce 560TI W.C. in SLI, six Western Digital drives for a total of 4.07 TBytes, AquaComputer Aquero 5 Pro, AquaComputer D5 pump, Multiswitch USB, tubemeter and Kyros CPU block. Two coolant loops,CPU & SLI, MB, RAM and AQ5, with two flow meters. Running Windows 7 Professional 64, and using Open Hardware Monitor v0.5.1Beta Aquasuite B16 hardware temps.
Buckey
Donnerstag, 7. März 2013, 07:57
I feel your pain on that one!
