• 01.10.2026, 02:25
Phatboy69
XML Export Error/Bug Aquasuite 2012-6
Donnerstag, 14. März 2013, 08:23
After setting up XML data export I get the following error when I reboot and Aquasuite restarts. Currently the only way to fix this is to reinstall Aquasuite and delete existing settings when prompted.
If I dont setup XML export, I can stop and restart Aquasuite fine.
1st Application Error
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
Log Name:      Application
Source:        .NET Runtime
Date:          14/03/2013 6:14:39 PM
Event ID:      1026
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Hilton-PC
Description:
Application: aquasuite.exe
Framework Version: v4.0.30319
Event ID:      1026
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      Hilton-PC
Description:
Description: The process was terminated due to an unhandled exception.
Exception Info: Microsoft.CSharp.RuntimeBinder.RuntimeBinderException
Stack:
   at DynamicClass.CallSite.Target(System.Runtime.CompilerServices.Closure, System.Runtime.CompilerServices.CallSite, System.Object)
   at System.Dynamic.UpdateDelegates.UpdateAndExecute1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.Double, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.Runtime.CompilerServices.CallSite, System.__Canon)
   at AquaComputer.Logdata.LoggingProcess+LoggingJob.AddLogDataFile()
   at AquaComputer.Logdata.LoggingProcess+LoggingJob.AddLogData()
   at AquaComputer.Logdata.LoggingProcess.DoLoggingJobs()
   at AquaComputer.Logdata.LoggingProcess.workerThreadMethod(System.Object)
   at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
   at System.Threading.ThreadHelper.ThreadStart(System.Object)
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name=".NET Runtime" />
    <EventID Qualifiers="0">1026</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2013-03-14T07:14:39.000000000Z" />
    <EventRecordID>101294</EventRecordID>
    <Channel>Application</Channel>
    <Computer>Hilton-PC</Computer>
    <Security />
  </System>
  <EventData>
    <Data>Application: aquasuite.exe
Stack:
</Data>
  </EventData>
</Event>
Followed by this error
Quellcode
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Application Error" />
  <EventID Qualifiers="0">1000</EventID>
  <Level>2</Level>
  <Task>100</Task>
  <TimeCreated SystemTime="2013-03-14T07:14:40.000000000Z" />
  <EventRecordID>101295</EventRecordID>
  <Security />
  </System>
- <EventData>
  <Data>aquasuite.exe</Data>
  <Data>1.0.0.15</Data>
  <Data>50d196c6</Data>
  <Data>KERNELBASE.dll</Data>
  <Data>6.1.7601.18015</Data>
  <Data>50b8479b</Data>
  <Data>e0434352</Data>
  <Data>0000000000009e5d</Data>
  <Data>11d4</Data>
  <Data>01ce208396989bad</Data>
  <Data>C:\Program Files\aquasuite 2012\aquasuite.exe</Data>
  <Data>C:\Windows\system32\KERNELBASE.dll</Data>
  <Data>d5f00646-8c76-11e2-9828-0026833a26bf</Data>
  </EventData>
  </Event>
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Donnerstag, 14. März 2013, 11:02
Thank you, the bug is fixed in the next version.
The next version will be released end of the month.
jpmboy
Donnerstag, 14. März 2013, 18:31
Excellent! :thumbup:
AsRock E3Gen3, 2700k @4.6 with cuplex HF, 2 HD7970s with aquaC waterblocks, 16G GSkill 2133, TJ09, ST1500 ps, plextor 256 ssd, 2x1TB WD VRs raid 1, HP 30 inch. Aquacomputer 720XT Mk IV.
Phatboy69
Dienstag, 19. März 2013, 08:14
FYI a clean win 7 64bit install with full .net 4 client and C++ updates has fixed this crash. Not sure what it was.
I still however get an immediate crash when I try and add a fan sensor value to xml export.
