• 14.10.2026, 20:17
pilotter
Aquaero5 xt and mcp35x2
Freitag, 12. April 2013, 10:03
Good day,
does someone has a mcp35x2 pump(s) connected to the aquaero 5 and working properly? what I would like to see , make possible control of the pumps ( same speed ) and readout of both pump rpms separate.
Jakusonfire
Sonntag, 14. April 2013, 12:28
Swiftech has a PWM splitter cable that will allow you to connect both pumps together for control by the fan 4 header and it has a seperate 3 pin header that connects to one of the other fan headers and will give the RPM's of the second pump.
http://www.swiftech.com/PWMsplittercable.aspx
tpb211
Mittwoch, 17. April 2013, 23:11
Just be sure to go to the fans tab, advanced setting and make sure PWM is checked and you shouldn't have a problem. As stated above use the included Y-splitter and send the second feed to ch.3 or another channel on the aquero and it will show you both rpm's. You will be able to control both rpms simultaneously via making adjustments to ch.4
I am running a pair of MCP35x2's in my build if you have any questions just ask! Great pumps!
pilotter
Freitag, 26. April 2013, 05:56
thanks, so it will be shown as a fan? But than you can control the 2 pumps simultaneously and read the rpm, great. :thumbsup:
