• 18.11.2026, 20:13
cincilleo
Aquaero 5 preset values LOST
Samstag, 20. April 2013, 11:24
When i set preset voltage and rpm values for fans, in a while aquasuite change them to whatever aquasuite wants.
Let me explain...
I set minimun voltage for channel 1 is 4volts and max 6 volts, after a couple of MINUTES aquasuite automatically change to 4 minimun and 10 maximum...
WHY???
Why aquasuite don't record the preset values that i want?
Thanks
tpb211
Samstag, 20. April 2013, 20:08
Have noticed the same issue in AS2013-2, what I have found that works for me is after I make a change I immediately save it by clicking the disk icon (located on the left pane Aquero 5 tab next to the gear icon).
Hope this helps and works for you as well. Please update!
cincilleo
Sonntag, 21. April 2013, 13:32
I tryed to click immediately and also many times.
No way for me... Please help
Montag, 22. April 2013, 07:02
What temeperatures have the Fan outputs (Amplifier temperature)?
When the temperature is to high, the output goes to 100%.
cincilleo
Montag, 22. April 2013, 11:17
i know that.
But i have the heatsink with a 120mm fan blowing on it... It's always under 60° celsius in all four channels...
Maybe a bug in the aquasuite?
mandrix
Montag, 22. April 2013, 12:13
Try saving and then close Aquasuite, then reopen it after a little bit.
Aquasuite has had this bug for a while and I have told them about it.
I have one unused Fan header on one of my Aquaero's and it want's to default to 2.4V once in a while although I set it at 0.
What made me first notice this is I had a backup pump connected to a PA2, and merely by opening the Fan tab would occasionally cause the header to power up the pump, although I had set it at 0%..
A workaround might be to use a controller for the fan header. This way the header can be set at 100% and the settings inside the controller won't let the voltage deviate.
cincilleo
Montag, 22. April 2013, 23:11
Explain me the way that you are saying...
Same problem on the empty channel, i set 0 volts and doesn't save it...
What you are talking about for using a controller for the fan header???
mandrix
Montag, 22. April 2013, 23:49
You can try this, it has worked for me I found out by accident.
For an empty channel set the power % to 100 :
Assign the Fan channel to a curve controller just like you normally would, except set all the power settings at 0% on the controller. Use whatever temperature you want for a datasource.
For any other Fan header you are using set the header at 100%, then just use a controller.
In my experience anyway, the Fan channels are pretty well governed if a software controller is used.
If none of these work for you then something is going on I know nothing about.
cincilleo
Dienstag, 23. April 2013, 12:08
Ok i will try... You are saying that if the fans are not in a controller they became "crazy" right?
mandrix
Dienstag, 23. April 2013, 12:27
Pretty much. If a controller is being used then the settings on the Fan tab don't seem to "wander" so much, at least with the curve controllers which is all I use.
Could be a coincidence but worth a try.
