• 06.10.2026, 01:53
Jakusonfire
Freitag, 26. April 2013, 19:20
A Laing 355 18 watt pump can generate 1.65 PSI at around 400LPH, a low restriction CPU block like a raystorm generates more restriction than that at 400LPH.
Unless you are running only a CPU block with the pump, you are not getting accurate results.
cincilleo
Samstag, 27. April 2013, 12:42
http://www.ybris-cooling.it/laing-pompa-p-2984.html
Is >900lt/h and 5,7 meters headpressure
Not the same model that you are talking
Jakusonfire
Samstag, 27. April 2013, 16:57
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Jakusonfire« (27. April 2013, 17:01)
cincilleo
Samstag, 27. April 2013, 19:28
ok
