• 30.09.2026, 08:12
Psychor
MPS 400 Internal Temp. Sensor?
Samstag, 27. April 2013, 09:04
All hardware and fans in the PC are off (including pumps) except the AQ5 Pro. All case side panels are off.
Ambient room temp. = 23C
MPS 400 internal temp. probe = 27C
Delta = 4C
Is such a difference typical? Should I just set the MPS internal temp. in Aquasuite = ambient room temp and be done with it?
Thanks.
_KaszpiR_
Samstag, 4. Mai 2013, 19:55
I suggest leaving the computer off overnight so the temperatures will stabilize.
You may alos turn off computer, leave pump and fans to on at full speed and then try to cool down to the ambien tmeperature.
Then turn off the fans and pump and wait till it stabilize.
Second, check out also with external sensors, some may also have wrong offsets (so use two or three, and calculate average).
Psychor
Sonntag, 5. Mai 2013, 14:07
Good suggestion! It appears that the difference isn't as bad as I first thought - the MPS is still off but about +1.2C.
I'm using a standalone external temp. sensor and two AQ temp. probes to measure ambient.
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Psychor« (5. Mai 2013, 14:29)
_KaszpiR_
Sonntag, 5. Mai 2013, 22:02
Then go and adjust the offset :)
Psychor
Sonntag, 5. Mai 2013, 22:10
Yup. That's what I did. :thumbsup:
Jakusonfire
Montag, 6. Mai 2013, 10:29
This is a good read for anyone with an MPS sensor
http://www.xtremerigs.net/reviews/access…00-flow-sensor/
mandrix
Montag, 6. Mai 2013, 12:26
Thanks for that link, Jakusonfire. Very good read on the mps sensor and answers some questions I've had. :thumbup:
