• 30.09.2026, 22:20
Barney Gumble
Aargh. M4 screws please.
Dienstag, 30. April 2013, 14:07
I have bought the D5 pump adapter & Aqualis reservoir. D5 mounted on adapter with included countersunk M4 (x 12mm, I think) screws. This assembly is called to be mounted on the reservoir with the same size screws and there was only the one set!
Where or how can I get more? No WC online store I can find sells them.
Thanks.
Jeremy
RE: Aargh. M4 screws please.
Freitag, 3. Mai 2013, 09:30
Barney Gumble
Freitag, 3. Mai 2013, 15:01
Believe it or not I did try that.....and didn't find any countersunk versions. However your search did so thanks! :thumbup:
