• 11.10.2026, 10:30
Brodholm
Dimming Led strip from a Fan port on a Aquaero 5?
Freitag, 17. Mai 2013, 11:30
Hello!
I have been thinking about dimming a led strip fro a Fan header on the aquaero 5. I think it should be possible.
I will be using the Bitfenix Alchemy led series. the 300mm strip is rated at 0.36W on 12V. And you power them from a simple molex connector. So I just thought of switching them to a fan header and be able to dim them or completely turn them off.
So for example, If I dim them to 5V it should be around 0.72A (3,6/5=0,72A). That should be fine considering the 1.65A per fan channel and a total of 20W on the whole unit. And I also belive that you are able to totally turn of one fan header allowing you to turn of the leds. Or am I wrong.
Here are my calculations:
p=u*i
3,6/12=0,3A on 12V
3,6/5=0,72A on 5V
Or is there a better way to do this? like on the PWM1 and PWM2?
Namron
RE: Dimming Led strip from a Fan port on a Aquaero 5?
Freitag, 17. Mai 2013, 11:49
^ This is the much better & proper way to do it when it comes to LED strips, I do it myself & it enables you to control the lights pretty much anyway you wish as regards ajusting the voltages & setting up a Dim control e.t.c :)
N.
Brodholm
RE: RE: Dimming Led strip from a Fan port on a Aquaero 5?
Freitag, 17. Mai 2013, 11:51
N.
Okay, thanks for the reply. How does that work. Do you just connect the two cables to one of the PWM ports? IE the + and - from the 12v?
And are you able to turn of the led completely that way also?
And what contacts fits that connector?
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Brodholm« (17. Mai 2013, 12:02)
Namron
Freitag, 17. Mai 2013, 13:29
Not sure where your based Anderas, but you need connectors like these
<img src="http://shop.aquacomputer.de/images/product_images/info_images/53036.jpg" alt="Plug for relay or power output connector, 2 contacts (for aquaero)" align="left" />
& Just cut the molex connector off your LED strip & connect wires to this, then plug into either of the PWM 1/2 socket's...
You can then control them Via the "Controller" Menu from the Aquasuite 2012 software using say a "Preset Value" (I have mine set on a preset value of 40%) or even on a "Curve Control" (the LED's can then be set up to brighten or dim depending on temps e.t.c) the choice is yours :)
& Yes you can switch them off completely if you wish by just setting the power value to "0" (zero)...
N.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Namron« (17. Mai 2013, 13:33)
Brodholm
Sonntag, 19. Mai 2013, 16:48
Thanks for the answer! I actually had one of those contacts. I thought it did not fit, but with some gentle wiggle it went straight in! Thanks a lot!
