• 09.10.2026, 18:19
sandchicken
GTX TITAN acrylic glass edition, nickel plated version
Samstag, 8. Juni 2013, 18:27
Hi. Purchased this GPU water block from a US supplier and noticed damage and flaws. It was received new in box and vacuum sealed. Who should I contact regarding this issue?
sandchicken
Sonntag, 9. Juni 2013, 01:58
Also semi-related: Does the GTX Titan active backplate fit the GTX 780?
sickophant
Mittwoch, 26. Juni 2013, 06:48
Maybe you should go back to your U.S. supplier!?
Pilo
Mittwoch, 26. Juni 2013, 07:41
Sure, it would fit, but why should you need active cooling for the back RAM chips...for a graphic card with no RAM at the back at all?
The Titan has 6 GB RAM, 3 GB on both sides. The GTX 780 only has 3 GB at the front around the GPU.
