• 22.11.2026, 22:08
Cobra26
Some questions for Aquastream XT pump..
Freitag, 28. Juni 2013, 07:33
Hi Aquacomputer staff,
Im happy with the XT pump and now i want to change my tubing to 1/2ID - 3/4OD is there any issues since it is "highflow" with the pump?
Also what is the best way to clean the INSIDE of the pump if possible? Or is removing the impeller and clean any possible gunk or residue enough from the impeller?
I got the standard version so i assume i can manually adjust so the pump so it can push water at a higher flow with the provided software on your site? Or is it enough to let the pump adjust automatically when i have the 1/2-3/4 tubing?
May i use this sleeved black usb cable instead of the one you provided since im doing a project and i prefer no white or whitish cables to be seen. This is the cable i planning to get are there any problems with this cable?
http://www.aquatuning.nl/product_info.ph…---Schwarz.html
Also i need an extension for my 3 pin cable to my motherboard cpu 3pin socket (rpm) you also provided which is a bit to short for my liking so can i use this one instead (also for the colour)?
http://www.aquatuning.nl/product_info.ph…cm---zwart.html
These are the correct adapter fittings for the pump right?
http://www.aquatuning.nl/product_info.ph…art-nickel.html
A bit offtopic...
Any plans in releasing a gtx 770 full nickel plated water block?
Thanks in advance
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Cobra26« (28. Juni 2013, 07:36)
Cobra26
Freitag, 28. Juni 2013, 20:57
I just wanted to tell i already had a PM from Aquacomputer which answered all my questions in full.
I wanted to thank the Aquacomputer staff for responding so quickly. THUMPS UP!
This thread can be locked.
