• 17.10.2026, 15:21
pegleg
need help asap
Sonntag, 4. August 2013, 01:01
i just got done doing new build and hook my power adjust 2 up but now my fans are not working all fans and my aquaero5 is cahnging really fast for no reason so right now i have no fans working no rmp nothing,,ok was molex was not in all the way now can somebody help me with this power adjust2 how do i hook this up?
also on my aquaero5 i have 4 fans hooked to one channel now on channel 1 or fan controller 1 i have only 3 fans spinning and on my other channel2 i only have 3 fans spinng why on both channels only 3 fans are spping instead of 4 fans spinning i'm i doing something wrong need help.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »pegleg« (4. August 2013, 03:19)
braindeadmac
RE: need help asap
Sonntag, 4. August 2013, 15:28
That's a fan wiring problem, not an aquaero problem.
Grasshopper
Mittwoch, 7. August 2013, 10:11
make sure you are above minimum voltage for the fans.
pegleg
Samstag, 10. August 2013, 07:56
yea i got it thanks all, it was my fan connector was bad got another one and all is good.
