• 08.10.2026, 11:03
Seanimus
Seanimus448 Aquacomputer Build
Montag, 5. August 2013, 16:39
Hi wanted to share the final build pictures which can be seen as overclock.net site.
Full AQ Build - Dual Loops.
2 x AQ 5,
2 x 420 AMS,
2 x Aqualis/D5/Adaptor,
2 x Flow Meters.
2 x Jeak's RGB Amps
All connected via USB. RGB's in each reservoir, are controlled by AQ5's read of CPU or GPU temperature for their respective reservoir.
Some pictures shown here.. full log above at overclock.net has the complete set of pictures.
July competition has started at overclock.net. If you like this AQ Build, vote for Seanimus448 at this link.
http://www.overclock.net/t/1410524/july-…nner-today/0_20
You have to be registered at overclock.net and if new registration your email needs to be verified before voting.
Thanks.
Grasshopper
Mittwoch, 7. August 2013, 12:24
wow :)
is the HDD power cable a custom item?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Grasshopper« (7. August 2013, 12:25)
Seanimus
Mittwoch, 7. August 2013, 20:57
All 200 feet of cabling is custom, including USB 2.0. Only cable not custom, is the USB 3.0 and SATA Data cables.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Seanimus« (7. August 2013, 21:01)
