• 14.11.2026, 12:36
DarkRanger
Problem with Aqua Computer Windows Service
Dienstag, 13. August 2013, 01:44
I just bought an Aquaero 5 Pro, updated to FW 1030, and I'v got a problem running the Aquasuite 2013-2 properly. The problem seem to be related to the Aqua Computer Windows Service who simply wont start after the reboot of my computer if I went in the Aquasuite on the Sensor section and I play with the Software sensor settings, even without changing them. To get the service working again, I have to make a fresh install of the Aquasuite asking to delete previous info, and as soon as I go in the Software sensor setting section, the problem comes back and the service will be unable to start on the next reboot, event if I try to start it manually from the Windows Service Manager. I did try a reset of my device, without success.
Running Win7 64 Ultimate Fr-Ca, this is the error that I get when I try to start the service from the Aquasuite program with administrative rights:
Signature du problème :
Nom d’événement de problème: CLR20r3
Signature du problème 01: aquasuite.exe
Signature du problème 02: 1.0.0.15
Signature du problème 03: 51529514
Signature du problème 04: aquasuite
Signature du problème 05: 1.0.0.15
Signature du problème 06: 51529514
Signature du problème 07: c08
Signature du problème 08: 39
Signature du problème 09: System.ApplicationException
Version du système: 6.1.7601.2.1.0.256.1
Identificateur de paramètres régionaux: 3084
Information supplémentaire n° 1: 9d9f
Information supplémentaire n° 2: 9d9fb032a03c82630760de935ea4b9b0
Information supplémentaire n° 3: 8463
Information supplémentaire n° 4: 846349d1a32e1d502af67a865a02337f
Sorry for the french log, but it's the language of my system...
If anyone have a solution, please let me know.
DarkRanger
Freitag, 27. September 2013, 03:58
Just an update,, I've been forced to format my computer, and once everything was plugged back, it just worked perfectly.
Guess I'll never know what the problem was...
