• 22.11.2026, 22:33
SeeThruHead
Aquaero 5 LT : Making sure I'm setting this up correctly.
Donnerstag, 22. August 2013, 08:25
This is a rather complex piece of kit so I want to make sure how I'm going to set it up is actually going to work before I connect everything together.
I've got one Aquaero 5LT and one poweradjust 2 USB.
I would like to control 9 Swiftech helix 140mm fans (~7 - 13.8 VDC, 0.45 A) I would like to connect these in 3 channels with 3 fans each, but if the aquaero can only take 2 fans per channel I could connect 2 fans on each channel and 3 fans to the poweradjust 2 USB.
Two MCP35x (Connected with swiftech MCP35x2 PWM splitter) Connected to fan 4 for pwm control
I would like to control everything through the aquasuite. I have two bitspower water temp probes to connect and will control the fan speed and pump PWM based on their temperature readings
So would this work?
Is there anything I should know about before hooking this stuff up?
Grasshopper
Freitag, 23. August 2013, 11:48
optional extra water cooling block for AQ5
http://shop.aquacomputer.de/product_info…roducts_id=2671
