• 12.11.2026, 19:56
pumba2988
Power Adjust?
Dienstag, 8. Oktober 2013, 23:28
Okay I need to find out what on earth does a
Poweradjust 2 USB do exactly?
Also why do you have to buy 3 separate to be screwed together in one 5.25" Bay Device.
Also what is the point of the
Multiswitch?
Thanks :thumbup:
Nihil Simile
Mittwoch, 9. Oktober 2013, 03:28
You don't need three, The Power Adjust is the same as a fan header on the Aquaero 5 XT , Pro, or LT when it is connected to the aqua bus High side header on the Aquaero also called aqua bus #2. It can handle more amps so you can control a pump or a large fan with it. When connected to the Aquaero via the aqua bus High Side header it will show up as fan 5 you can change this to Pump in the Aquaero menu. If you need to power more high amp accessories then you add more Power Adjusts.
pumba2988
Mittwoch, 9. Oktober 2013, 09:52
Thanks i feel so noob right now :(
well as they always say knowledge is power :D
