• 03.10.2026, 00:22
fr4nc3sco
help my aquaero 5xt goes into loop
Sonntag, 3. November 2013, 12:59
I have a problem my Aquaero 5XT after a while is that access must be looped like holding down the button to scroll through the pages and does not stop until the detachment mains I tried already to remove the usb cable levari the various cables and fans to make it go empty but equal after a certain number of minutes it always does well or tried to remove the batteries from the controller the same there is a remedy? or do I have to RMA? was purchased by the Italian riventore Ybris and directed me here for assistance
appel
Dienstag, 5. November 2013, 15:16
i tried to read it 5x and i still have no clue what you are doing and what the problem is.
fr4nc3sco
Dienstag, 5. November 2013, 18:20
the display starts to show all the information as fast as if you pressed the down key always, I tried to loosen the screws of 3 flared but nothing if I remove the cover front display stops making the problem as if there was a short or something on the first multi-function 3-button dispay, among other things I saw in the book reviews that there are 3 red LEDs on the keys are off on my
Nihil Simile
Mittwoch, 6. November 2013, 02:23
Sounds like you may be having the Hyper sensitivity problem with the touch capacitance button. If this is the problem I am not sure but I think in the Aqua suit you can adjust the sensitivity of the button and even disable it. I had problems with mine and when I changed the PSU the problem quit. But I believe the newer version has better hardware so if yours is fairly new this may not help might need to RMA.
