• 12.11.2026, 18:54
pegleg
2 aqua stream xt pumps
Dienstag, 5. November 2013, 03:33
just need some advice .I can run 2 pumps in serial i'm i right. like one pump then connect the other pump out water 2 in water then out on 2 pump
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »pegleg« (5. November 2013, 03:34)
Pilo
Dienstag, 5. November 2013, 09:11
Yes. The 'IN' from the first pump needs to be connected to the 'OUT' from the reservoir and the 'OUT' from the first pump goes directly into the 'IN' of the 2nd pump and from the 'OUT' of the 2nd pump to your water blocks or whatever comes next in your loop.
appel
Dienstag, 5. November 2013, 15:15
I have the same setup,
there is a bad thing about this though,
if you dont run the 2 pumps at exactly the same speed, they break down quicker.
this is why i first tried to put them parallel but then if one pump fails it just short loops back through this one.
connect them like you thought (and how pilo described it) and make sure you get them running at the same speed.
pegleg
Dienstag, 5. November 2013, 23:06
ok, I thank u both on the reply when i do my next cleaning witch will be very soon i will be adding the other pump i have.
one pump has to be on one channel then the other pump on the next channel right?
so is it bad to run 2 pumps then?
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »pegleg« (5. November 2013, 23:10)
appel
Mittwoch, 6. November 2013, 13:16
what do you mean with channel?
and its oke to run 2 pumps as long as you fix their speed to exact the same.
