• 15.11.2026, 22:42
liberato87
aquasuite 4.72 - windows 8.1 ?
Samstag, 9. November 2013, 19:11
hi!
I have upgraded from windows 7 to windows 8.1
I am trying to install aquasuite 4.72 (i have an aquaero 4 usb) but when I get a message
".NET runtime library v 2.0 or newer is required. you have."
I have the latest runtime library (I think 4..).
where is the problem??
Windows 8.1 It is not compatibile with aquaero 4??
Samstag, 9. November 2013, 21:28
It is compatible. You just have to install .NET 3.5 - it includes NET 2.0
liberato87
Sonntag, 10. November 2013, 00:44
thank you stephan!
I have installed net. 3.5 and aquasuite work! but aquaero not recongnized into aquasuite, even if it is still working "standalone" with my old setup on windows 7:(
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »liberato87« (10. November 2013, 00:46)
liberato87
Dienstag, 12. November 2013, 10:26
still not working..
I can open aquasuite but no device showed.
If I select "find usb device", nothing found.
I windows aquaero was before "aquabus" but with driver problem and now is "generic usb hub"...
please help me
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »liberato87« (12. November 2013, 11:20)
liberato87
Freitag, 15. November 2013, 12:25
nobody??? support??
Freitag, 15. November 2013, 14:31
The device is not found from the OS.
Try to plug/unplug the aquaero. Try it with a other USB port.
liberato87
Freitag, 15. November 2013, 17:45
tried but nothing changes..
it is "generic hub usb"
and the drivers are usb3uhb3.sys and asusfilter.sys ...
are there specific driver?
Freitag, 15. November 2013, 17:59
The device is not correctly registered (USB). Until the usb is not correctly initialized the aquasuite cannnot find the device.
liberato87
Samstag, 16. November 2013, 01:28
ok i know..
but how I have to proceed??
I tried all internal and esternal usb and same problem.
are there specific driver that I can "force" to install ?
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »liberato87« (16. November 2013, 01:48)
liberato87
Samstag, 16. November 2013, 11:31
this morning i tried plugging the aquaero to a laptop with windows 8.1 and everything is fine!
plugged then installed as "aquaero 4.00".
on my pc is installed as "aquahub" and not working :(
dont know why it is not working on my pc, maybe the new motherboars asus
maximus vi hero (I red of problems with asus mainboard..).
so, for the moment I will configure the profile on the laptop and let it work stand alone on my pc.
maybe I have to wait some new bios from asus
I need an info :
- how can i change language on aquaero display??
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »liberato87« (16. November 2013, 12:16)
