• 08.10.2026, 08:57
grifftech
Question about the 6 XT and its capabilities with PWM fans
Montag, 18. November 2013, 02:26
Sorry for such a noob question as I am very new to all of this. I have 2 radiators with 6 PWM fans on each and I have a temp sensor on the outlet of each radiator. I am wanting to control the fan speeds based off of the temp from the sensor.
So would I have to hook 6 fans into 1 channel on the 6 XT and then use the temp signal to control that channel, and is that possible? Also would it control the fans via PWM?
Thank you so much, :rolleyes:
Chris
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »grifftech« (18. November 2013, 02:32)
appel
Montag, 18. November 2013, 13:21
if you in total have just 12 fans (2x 6) you can also put 3 on each channel.
with the curve controller you can take 1 (or more if you make virtual temps) temp to control 1 or more fan channels.
about the pwm part, i'm not sure, logic dictates it should work.
grifftech
Sonntag, 19. Januar 2014, 20:54
Sorry to resurrect my old thread, but I am now able to buy the 6XT but have one question. What do I use to connect 3 fans into one channel? My fans are GELID PWM fans with just a 4 pin connector.
wa3pnt
Sonntag, 19. Januar 2014, 21:58
You'll need a couple of Wyes like these:
http://www.performance-pcs.com/catalog/i…oducts_id=24882
RodeoGeorge
grifftech
Sonntag, 19. Januar 2014, 22:03
RodeoGeorge
But the channel connectors on the 6XT are 4 pin and all my fans are 4 pin connectors.
wa3pnt
Sonntag, 19. Januar 2014, 23:07
Sorry, I referenced the wrong cable. You are absolutely correct. No 3 pin, but all 4 pin that only have the RPM signal on one leg.
Here you go:
http://www.performance-pcs.com/catalog/i…oducts_id=31755
RodeoGeorge
