• 29.11.2026, 17:50
Totalslaughter
Aquabus D5 pump issue
Dienstag, 26. November 2013, 04:03
I was successfully running my D5 aquabus connected to the motherboard usb header with aquasuite and the power supply with molex connector. I updated aquasuite when prompted and then updated pump firmware when prompted and once I restarted the pump is no longer properly detected in Windows device manager. I can not get aquasuite to detect the pump to control it. Is there anything I can do to revive the pump after the firmware update apparently broke it?
Win 7 pro x64
Asus Maximus VI Hero
i7-4770k 4.5ghz
Gskill 8GB 2000mhz CL9
Seasonic X-1250 PS
Specwise shouldn't have an issue. Was working before, just can't get it working since software / firmware update. Thanks.
Dienstag, 26. November 2013, 07:33
Test ist on an other normal not overclocked Computer.
