• 22.11.2026, 21:01
bmxer4l1fe
Aquabus and high flow USB sensor
Sonntag, 9. Februar 2014, 01:54
I have an Aquero 6 xt and 2 high flow USB sensors
1x http://shop.aquacomputer.de/product_info…roducts_id=3093
2 x http://shop.aquacomputer.de/product_info…roducts_id=2897
Is it possible to connect both of the flow sensors to the aquero 6 using a 4 pint aquabus splitter cable?
http://shop.aquacomputer.de/product_info…roducts_id=2847
~ thanks
madcratebuilder
Mittwoch, 12. Februar 2014, 15:31
From what I have read you can use a Y cable with the Aquabus to monitor two flow meters. I believe before you can use the Aquabus, you must first use the USB connection to establish the address of each devise.
I'm waiting on two parts before I can start my new system, so my advise is only theory.
