• 10.10.2026, 00:10
ltorsini
Bad math?
Donnerstag, 20. Februar 2014, 17:55
Hello All -
I am new to the forum and Aquasuite but am enjoying both. I have a problem setting up a virtual sensor, it appears that the software miscalculates the data. I'm trying to run my cooler fan speed off of a temp delta (see attached file 'bad math') and have a CPU temp of 93 and a cooler outlet temp of 80. 93-80=12 but the Aquasuite software gives a value of 42. I've tried changing to C, reloading the software and switching between modes but nothing seems to do the trick. The same happens with the other delta algorithm I use to control my case fans. Both system and Aquasuite settings have Farenheit selected.
Any insights?
»ltorsini« hat folgendes Bild angehängt:
Freitag, 21. Februar 2014, 06:52
The aquaero claculate all internal values in K and °C.
The differences are internal stored in K. The conversion from a difference is not possible to °F in this case.
