• 09.10.2026, 09:10
thrgk
How to remove connection on 7970 WB for use with MULTI GPU Connector
Sonntag, 23. Februar 2014, 03:22
Hello,
I have a few 7970s with aqua blocks, and I am not sure how to remove the top black part, where the barbs go, so that I can then connect the aquacomptuer SLI/Crossfire multi gpu connector. What tool would I need to remove it?
Thanks
Pilo
Sonntag, 23. Februar 2014, 04:21
I'm guessing you need an Allen Key, but I don't know what size or if it must be a metric one.
thrgk
Sonntag, 23. Februar 2014, 04:25
yea I was not sure of the size or if its metric, can someone answer these questions? id rather not fiddle with it too much without knowing for sure.
Thanks!
Rostiger
Montag, 24. Februar 2014, 06:18
hi,
in all what I know is used a 3mm metric key, this means is a 4mm metric screw.
