• 10.10.2026, 06:30
Psychor
Mittwoch, 26. Februar 2014, 21:56
So how has the most recent version of AS been working with recent releases of AIDA?
mandrix
Mittwoch, 26. Februar 2014, 22:42
Fine.
But I still get an occasional drop out of the software sensors that requires a reboot to fix.
novax1
aquasuite 2014 1.3 y Hwinfo64
Donnerstag, 27. Februar 2014, 09:29
losiento ERASE can not duplicate this post
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »novax1« (27. Februar 2014, 09:36)
novax1
Donnerstag, 27. Februar 2014, 09:31
sorry I was wrong
Dieser Beitrag wurde bereits 6 mal editiert, zuletzt von »novax1« (27. Februar 2014, 11:05)
Deema
still HWinfo64 issue
Donnerstag, 15. Mai 2014, 12:12
Actual tandem of Aquasuite + HWInfo64 doesn't work. Anyone, who made that configuration operable: which changes You made to make it work?
OS: Win7SP1 + actual post-SP1 updates from MS
WMI service is running
HWInfo64 monitors the sensors fine.
»Deema« hat folgendes Bild angehängt:
Railgun
Donnerstag, 15. Mai 2014, 16:48
I'm running Win8 and haven't had any issues since the latest version of AS. Been pretty solid over hours of use.
josetortola
Sonntag, 15. Juni 2014, 16:23
I have the same problem with Aquaero Service stopping itself: Aquacomputer windows service stopping itself
And, by the way, I also have this other problem:
I'd like to report a bug.
I have 3 GPUs, and I am using HWInfo64 to monitor my sensors.
I created 3 software sensors, one for each thermal diode, but they actually all read the data from the GPU #0.
Whatever sensor I select for GPU #1 and #2 actually read the equivalent data from the GPU #0.
I would use Open Hardware Monitor, but it's too old and it doesn't work with my 4960X
I have two GPU and even selecting the software sensors from a source in each one, both software sensors display the same: the information of the GPU #0
Regards.
