• 15.11.2026, 23:35
capjlpicard
Laing DDC pump
Dienstag, 1. April 2014, 12:32
Hi everybody,
I’m buying a pump Laing
DDC 3.25 18W to be used with my Aquaero 5 Xt + Poweradjust 2 USB Ultra. I’ve
got the adapter cable for Laing DDC pumps.
My question is: will I
be able to control the pump speed like I do for a normal fan ? I would like to control
it with a curve based on water temperature. Is that possible ?
Thanks for your help!
Paolo
Namron
Dienstag, 1. April 2014, 12:58
In short..... Yes!! :D ... Run it of the PA and you should see it as Fan #5 & control it just like you would a fan....
N.
