• 15.11.2026, 15:50
novax1
RE: Aquasuite and WMI support
Dienstag, 15. April 2014, 12:04
Hello
I'm trying to export data from HWiNFO64 AquaSuite 2014 -1.3
The problem when you export data are not updated.
To export LCDhype use has created a plugin to export XML
AquaSuite data perfectly updated.
But when I want to export data from hwinfo be updated, only works if I can enable or disable some options AquaSuite 2014
show image
( second image ) so that data is actualizen i work, I show an image, and disable active in Hfinfo64 then works
»novax1« hat folgende Bilder angehängt:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »novax1« (15. April 2014, 12:29)
novax1
RE: RE: Aquasuite and WMI support
Sonntag, 20. April 2014, 11:07
:love:
