Du bist nicht angemeldet.
Mittwoch, 30. April 2014, 06:52
madcratebuilder
. We are working on getting the ambient temps down. Insulation in the roof to R-40, new ceilings with two fans in our house and 4 new air conditioners our old air conditioner in the living room stopped working after 5 years of hard use.
madcratebuilder
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Namron« (1. Mai 2014, 17:56)
Hiya Larry.. No worries it's easy to get confused with it all & your eager to get things moving alongHi Namron no sir you did not miss understand I got confused with this. my bad mistake.
Not sure why or how you would connect fans to a USB Expansion Board?? (that you linked to?)...... Fans don't run off a USB???
Will be using Y Cabels to connect the fans to the pro 6.
Planning on using the Aquacomputer Dual DDC http://shop.aquacomputer.de/product_info…roducts_id=2359 to run the D-5 Pumps in Series (Single Loop)
1. Does the DDC come with mounting brackets?
2. Mounting brackets are not included what mounting brackets do you recommend?
3. I take it the pumps are mounted on the back side no pictures in the link?
4. Wires coming out of the block on both sides what are they for?
Reservoir Aqua Box http://shop.aquacomputer.de/product_info…roducts_id=2452
1. Can the Aqua Box be used in series or is it for dual loops only?
2. In the video it appears there is a second Reservoir?
Is it the Filter with Stainless Steel Mesh? http://shop.aquacomputer.de/product_info…roducts_id=2421
Pumps x 2 Aqua Computer D-5 pumps. http://shop.aquacomputer.de/product_info…roducts_id=2901
The pro 6 has one USB Connect. In order to connect 2 D -5 Pumps in series to get the pump information in the software is it better to use a Power adjust Ultra version or the standard version. Ultra has 2 x USB Connects?
1. Is it better to connect both pumps (USB) to the power adjust rather than one pump USB to the Pro 6 and the second pump to the Power Adjust?
http://shop.aquacomputer.de/product_info…roducts_id=2517
Will use a Multi Switch for the Power Adjust http://shop.aquacomputer.de/product_info…roducts_id=2572 with this front plate http://shop.aquacomputer.de/product_info…roducts_id=2531
This what trying to accomplish any and all help is more than appreciated.![]()
http://www.youtube.com/watch?v=eyffbCvnyyU
Thank You
...I would say though...Take a step back & Take a deep breath, relax but most importantly take you time....
)..... But any way give my quick guides a good read which should & will hopefully help you out with any further queries you may have.....
some times that is easier said than done LOL. -
