• 29.11.2026, 14:57
apw63
MPS 400 OD/ID fitting size, defuser plate, temp sensor connection.
Samstag, 10. Mai 2014, 18:21
Hello,
I'm installing a MPS 400 flow sensor in my new build. I read in the manual the the flow sensor is only calibrated to 10/8mm or 11/8mm fittings and tubing. Is this referring to ID/OD? I'm assuming the manual is referring to ID/OD. I'm using 10/12mm hard acrylic tubing thought out the build. . So I do need the defuser plate installed? I'VE REREAD THE MANUAL AND THE DEFUSER IS USED FOR SMALLER THAN 10/8mm OR 11/8mm. MY TUBING IS LARGER.
If I connect a inline temp sensor to the MPS 400 will it read out in the aqua suite and a regulate inline temp or will it read out as attached or under the MPS 400?
Thank you for any info.
Andy
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »apw63« (10. Mai 2014, 18:33)
Jakusonfire
Sonntag, 11. Mai 2014, 14:53
The default calibration for the 400 model is 10mm ID tubing. The defuser is not needed. Only the lower models have preset calibrations for narrower tubing.
madcratebuilder
Sonntag, 11. Mai 2014, 14:58
Here is the spec for the mps 400 flow sensor I have.
The symmetrical design with two identical nozzles allows integration
into the system without having to use a certain direction of flow
through the sensor. The connection threads are G1/4" in size and
therefore allow the use of the sensor with all common fitting and hose
sizes and types.
The spec is near the same for the USB flow meter. If you attach a temp sensor to the USB flow sensor it appears under "Sensors" in aquasuite.
apw63
Dienstag, 13. Mai 2014, 03:57
Thank you for the info guys, it was what I was looking for.
Andt
