• 14.10.2026, 21:19
arkwel
Problems with 2 Flow meters (USB and aquaero 6 xt)
Montag, 30. Juni 2014, 14:16
Good afternoon,
After plenty search, I come to ask here for my problem. In my new build I have two loops. Each as a D5 usb pump and a flow meter 200. the pumps are connected to the motherboard and recognize by Aquasuite. For the flow merters, I have first connected by USB. It's working good also (even if i have a very low rate). I check the address and gave the priority to the aquabus. I disconnected the USB cables and connect to the High connection with a Y splitter. And nothing... I'm certainly missing something... I know it' has been discussed plenty time but i can't find a solution to my problem.
Thank you,
Arkwel
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »arkwel« (30. Juni 2014, 14:20)
wa3pnt
Dienstag, 1. Juli 2014, 02:13
If you disconnect the USB, you must use a 4 pin Aquabus cable to provide power to the Flow Meter (MPS200).
RodeoGeorge
arkwel
Dienstag, 1. Juli 2014, 07:41
Hello,
I have do this several time. I disconnect the 2 usb cable from the flowmeter and connect with two 4-pin cables (by a splitter) to the aquabus... but I don't have any indication of flow in aquasuite.
Arkwel
wa3pnt
Dienstag, 1. Juli 2014, 08:24
I am not completely sure about what I'm going to suggest, as I have 2 MPS400, but I have both the Aquabus and the USB connected.
In Aquasuite, if the USB is not connected, the Flow Sensor will not appear as a component in the listing on the left. It will appear under the Aquaero > Sensors > Flow Sensors.
Do they appear there?
RodeoGeorge
arkwel
Dienstag, 1. Juli 2014, 18:30
Hello,
they should normally but I check all the time when I test but nothing... Stupid question there nothing special about the 4 pin cables? I bought longer cables (Phobya) to reach the aquabus¨in my 900D...
Thank You
wa3pnt
Dienstag, 1. Juli 2014, 19:08
Nothing special about the 4 pin cable.
Is the MPS visible in the Aquasuite Aquaero > System > Currently connected aquabus devices screen?
Here's my screen, with 1 MPS and 2 Poweradjusts.
RodeoGeorge
arkwel
Dienstag, 1. Juli 2014, 21:47
thank you for the answer,
it's weird because i have nothing in the "currently connected aquabus devices" not even the mps bus address. I have 2 D5 pump connected by usb. I will try to connect again one flow sensor directly to the aquabus. I start to think about a address conflict...
Arkwel.
