• 07.10.2026, 03:29
donohue100
Setting up fans to work with the aquasuite software?
Freitag, 22. August 2014, 14:25
Hello,
I have a couple of questions and it would be great if they could be answered. First of all this pump is great, when filling the system I thought it was not on as it made so little noise. My questions are as follows:
Can I change the minimum pump speed below 3000?
Can I create a custom profile to change pump speed based on water temp?
How do I go about adding fans to the pump to be controlled, does that need a fan controller or will it just need a channel splitter?
How many fans can the pump control on its own?
What is the deaeration mode and do I need to bother?
I have the ultra version.
Thank you in advance.
Rostiger
Dienstag, 26. August 2014, 17:53
i think you have a XT - Pump ?
To kontroll this Pump you can load the 4.72 Suite from the Download Aera by AC. The Speed is not give by rpm select by Hz 60Hz less or more give the Speed of the Pump.
To use this Suite the Pump need a USB - connektion.
The max Fan Power output is 5W on 12V if you use Y- Connektors for more then one Fan !!
