• 22.11.2026, 22:35
AE5probigNGslave
Aquaero 5 PRO and LT - occasional problem
Samstag, 30. August 2014, 22:55
Hello Aquaero fans,
I recently installed to my system next piece of aquaero (aquaero 5 LT). Now I have 1x aquaero 5 PRO and 1x aquaero 5 LT.
I use OHM (Open Hardware Monitor) and software sensors (sensors are from my bigNG :) ). Aquasuite 2014 is in version 2.3. System is Windows 7 pro 64 bit.
Firstly, I have found that they can not both use the same sensor from OHM !!!
Second, much more serious thing is that sometimes aquasuite mad, the main screen of aquasuite appears that aquaero 5 PRO and LT is disconnected from the USB !!!
Attention, will start my Razer Lycosa keyboard blink (like Morse Code - maybe SOS) and is non-functional.
Helps only reset, after reset, see attached picture.
I tried the keyboard into another USB, I completely reinstalled aquasuite. Without success.
Please community or clever heads from aquacomputer for help.
Among others, aquaeros are great monitoring panels !!!
BR
George
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »AE5probigNGslave« (2. September 2014, 23:43)
mandrix
Dienstag, 2. September 2014, 19:43
As per your pic, when you get an extra device page showing up, you can just delete it.
This happens usually after USB is disconnected or bad connection.
AE5probigNGslave
Dienstag, 2. September 2014, 20:38
Hello Mandrix,
New non existing device is not problem, problem is blinking Lycosa.
BR
George
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »AE5probigNGslave« (2. September 2014, 23:50)
AE5probigNGslave
Dienstag, 2. September 2014, 23:40
With regularity begins mentioned problem in the case, that I play longer with adjusting the voltage of the fans.
Once this problem occurred even when the PC is switched on.
I think aquasuite reaches somewhere ???, addressing equipment, or similar.
Can anyone from aquacomputer help?
BR
George
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »AE5probigNGslave« (2. September 2014, 23:50)
Mittwoch, 3. September 2014, 07:51
sens us a mailwith your questions: info@aqua-computer.de
