• 02.10.2026, 00:03
lcpmc
Aquaero 5 Pro Question
Dienstag, 2. September 2014, 12:13
Hello everyone,
Can I use 3/5mm UV LED via this controller, 1+1pin?
Dienstag, 2. September 2014, 16:29
Here is what I found in the manual:
"4.11. Connector „RGB LED“
Connector for up to three LEDs or one two-color or RGB illumination module
(not included in delivery). High brightness LEDs (3-4 V, 20 mA) may be con-
nected without series resistor, a series resistor is built into the aquaero.
Pin assignment:
Pin 1: VCC LED 1
Pin 2: VCC LED 2
Pin 3: GND
Pin 4: VCC LED 3"
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (2. September 2014, 16:41)
lcpmc
Dienstag, 2. September 2014, 21:08
Pin assignment:
Pin 1: VCC LED 1
Pin 2: VCC LED 2
Pin 3: GND
Pin 4: VCC LED 3"
Great stuff, thanks a lot!
