• 05.10.2026, 13:00
donohue100
horrible fan noise when controlled through the pump
Mittwoch, 3. September 2014, 18:35
I thought I would try a single fan controlled directly via the pump till I get a controller to go with it. The fan spins up and makes an awful squealing noise then ticks. When I took the fan out it still does this on my other fan controller. I tried another fan and the pump has damaged the fan in the same way. What is causing this?
Donnerstag, 4. September 2014, 07:12
The pump cannot damage the fan. This is not possible. The pump has an maximum voltage of 12V, your fans have also 12V.
donohue100
Donnerstag, 4. September 2014, 13:50
i am sorry but this is possible and has happened, 3 fans now squeak and tick after being connected to the pump.
