• 01.10.2026, 09:37
Reveal
720 Mark IV
Montag, 8. September 2014, 10:06
Welcome!
Ihastentoinformme,onthebasis of theaqueductsystemassembled720XT.
Russia:
Configuration
ASUSrampageBlackEdition
I74930
Corsair16PlatinumDominator2133
2 Way SLIGTX780TIEVGAhydrocooper
ENERMAX1350W
Corsairair540
Everythingworkslikeclockwork,Napruga146l/h
Temperatureinrunoff
CPU-31
GPU-31
Inthefurtherspreadof58degreesCelsius
Icanhelp-e-mailusatrepinekb@gmail.com
PreferablyinEnglish,likeopinions,someonecantellmetheAqua Suite menu.
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »Reveal« (8. September 2014, 10:19)
RE: 720 Mark IV
Dienstag, 9. September 2014, 17:12
Welcome!
I hasten to inform me, on the basis of the aqueduct system assembled 720XT.
Russia:
Configuration
ASUS rampage Black Edition
I7-4930
Corsair 16 Platinum Dominator 2133
2 Way SLI GTX780 TI EVGA hydrocooper
ENERMAX 1350W
Corsair air 540
Everything works like clockwork, Napruga 146 l/h
Temperature in run off
CPU-31
GPU-31
In the further spread of 58 degreesCelsius
Preferably in English, like opinions, someone can tell me the Aqua Suite menu.
(Added spaces in the quote for readability)
I find it uncanny how similar our builds are, mine listed below:
MoBo: ASUS Rampage IV Black Edition
CPU: I7-4930
Mem: 32GB Corsair Platinum Dominator 1866
GPU: 2 way SLI GTX780 TI EVGA with EK water blocks
PSU: Corsair AX1200i
Case: Corsair Air 540
The primary difference is I went with the Aquaduct 360 XT Mark V, and it does not allow me to load the system without heating issues. (1st watercooled build noob error)
I just ordered the airplex GIGANT 1680 with aquaero 6 PRO, copper fins which should serve me and allow for future upgrades.
At 31 C your temperatures look good, though I am not sure what the spread of 58 C is in reference to.
Unfortunately I cannot help much with your request for help with the Aquasuite. I have it running, but have not got into modifying it yet, and have not found a manual to date.
Good luck.
EDIT: I did find this REVIEW which discusses setting up the older Aquasuite 2012. (scroll down about half way)
Dieser Beitrag wurde bereits 6 mal editiert, zuletzt von »InfoSeeker« (9. September 2014, 17:47)
Reveal
Mittwoch, 10. September 2014, 04:22
Hello!
Yes the systemis similar.720XTshakes160 litersper hour,if it sset up.
So the temperature really is 58 degrees, the full load on the graphics cards.
Thanks for the link.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Reveal« (10. September 2014, 04:28)
Mittwoch, 10. September 2014, 07:13
This is NOT possible. The cange of the calibration value is only for the displayed value (Calculation base). The real flow is not changed.
Reveal
Mittwoch, 10. September 2014, 08:40
Who told you that doesn't change,learning to read:)
Write me my mail skeen sreen
Reveal
Mittwoch, 10. September 2014, 08:43
Ок 230 Impulse - 80 lh
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Reveal« (19. September 2014, 08:42)
Reveal
Mittwoch, 10. September 2014, 09:01
In the menu when the SENSOR FLOW tab change the value to100 and 220 you will have good luck.Say thanks to Russian overloker Xtream ;) ;) ;)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Reveal« (10. September 2014, 09:02)
