• 06.10.2026, 20:52
frank anderson
is my PA2 dead?
Donnerstag, 11. September 2014, 14:11
Was working fine, I have already tried the following.
Run the pump on another PA2 channel, it's working so it's not the pump..
Unplugged the pump from that PA2 and plugged in a fan, fan does not spin.
The red light on the PA2 is lit up.
Anything else I can do or should I RMA? also what is the warranty period on this?
Thanks.
Samstag, 13. September 2014, 18:32
Sure sounds like it is fail.
Recommend you complete the Supportformular
Google transaltion:
Support form
Take advantage of this form for inquiries to us. For warranty / repair is a separate form under RMA form available.
Please complete all fields carefully. Just as a quick processing!
Your name *
Your email address *
Subject *
Product name *
question *
Security Question (add the two numbers and enter the total)
Dieser Beitrag wurde bereits 7 mal editiert, zuletzt von »InfoSeeker« (13. September 2014, 18:43)
