• 03.10.2026, 06:03
Davey Dave
Aquaero Lt Dimensions.
Freitag, 19. September 2014, 09:51
Hey just looking for the dimensions for the aquaero Lt, most importantly the depth of the unit. And when using the mounting hardware if you can use a aqua computer cover plate, something like the cover plate from the aqua drive.
Thanks.
Sonntag, 21. September 2014, 02:05
Found this little tidbit in the manual
27.1. Technical details
Dimensions W x H x D:
148 mm x 43 mm x 59 mm (aquaero 5/6 XT/PRO)
144 mm x 42 mm x 22 mm (aquaero 5 LT)
As to the aquadrive Frontplate, the mounting hardware comments state "A front panel is not included, here the existing housing panel can still be used.". This tells me that the unit is set back slightly to allow the existing case cover to remain in place. If the mounting holes in the Frontplate align with the mounting holes on the aquaero 5 LT (looks like they might), and you wanted to use the Frontplate, you may need to use some spacers to make it flush with the case front.
Dieser Beitrag wurde bereits 7 mal editiert, zuletzt von »InfoSeeker« (21. September 2014, 02:45)
Davey Dave
Sonntag, 21. September 2014, 04:28
Thanks, that helps heaps! :D
