• 29.09.2026, 19:27
KBO
D5 Pump adapter with fill sensor.
Mittwoch, 22. Oktober 2014, 06:07
Is the bracket in this kit supposed to wobble when the screws are tightened?
The manuals are not very clear. They do need work.
I have four long washers with four long screws. The screws dont go in all the way using the washers.
I wont force them. Nothing else in the pack seems relevant.
Montag, 27. Oktober 2014, 08:54
Not quite sure what you mean. The holder does not work as a decoupling and should be fixed. Maybe you got the wrong distance rings or screws. The rings should have a height of 10mm and the screws a length of 20mm.
