• 06.10.2026, 03:22
abdoman
Swiftech MCP655-PWM & aquaero 6
Samstag, 8. November 2014, 08:27
i would like to ask something i just got aquaero 6 XT will these pump pump (Swiftech MCP655-PWM-DRIVE 12v) work with my aquaero or not ?? i did search all the internet but there's many yes's and many no's and i am so confused . any help please thank you for your time
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »abdoman« (8. November 2014, 08:29)
Samstag, 8. November 2014, 11:08
It will not work without a modification because these pumps have a faulty PWM implementation.
abdoman
Samstag, 8. November 2014, 15:40
thank you so much for your answer :thumbsup:
wa3pnt
Samstag, 8. November 2014, 18:25
Do yourself a favor and get the MCP35X2. Works perfectly with the Aquaero 6XT and provides outstanding flow rates at moderate speeds.
I recommend getting the optional heatsink an adding the 80mm fan.
RodeoGeorge
