• 22.11.2026, 09:43
mixsetup
Aqua Computer Cuplex Kryos Delrin for Socket AM3/AM Fittings
Mittwoch, 12. November 2014, 03:20
Hi all I'm new here I just bought an Aqua Computer Cuplex Kryos Delrin for Socket AM3/AM
Now before I buy fittings for it can it fit compression fittings or fittings for acrylic tubes?
I would like to do acrylic tubing but it depends on what can fit this block.
Mittwoch, 12. November 2014, 12:55
If this is the water block you speak of, then you can use any tubing system that uses G1/4 fittings, which is most of them..
