• 17.11.2026, 20:48
Bytales
MOunting the Clock Expansion MOdule on Aquaero 6 XT
Montag, 8. Dezember 2014, 18:11
Hy, i have a question, since i received today my order from AquaComputer, herein is a Clock Expansion Module, and i currently have the Aquaero 6 XT with the red radiator mounted. THe feet with the clock expansion module are not thought for the 6 XT when it has radiator mounted. Can it still be mounted with proper smaller metal feet ?
Do you have something like that on sale, or do i have to look for some myself ?
Bytales
Samstag, 17. Januar 2015, 20:25
It looks like im going to have to make the connection "off-site" through an extension, by the looks of it.
Another question remains.
By using this, you will get 2 Aquabus connections on the AquaAero.
Does it act like a Y-Splitter ?
bcikota
Samstag, 17. Januar 2015, 23:13
Hi Bytales,
Since I have the AQ5, I can't answer you first question, but for the second one, yes the Clock module acts as a Y-splitter.
Kind regards,
Boris.
Samstag, 17. Januar 2015, 23:16
Reading the producr page, that is what I see, a hard wired splitter.
"When monted, the Real Time Clock expansion module is connected to the aquabus (high speed) connector of the aquaero, the module itself features two aquabus (high speed) connectors for further expansion modules."
In case you are not aware, if you have the aquaero 6 XT connected to the motherboard with a USB cable, the clock module is not needed.
Bytales
Sonntag, 18. Januar 2015, 09:29
Then i guess im not going to need it. It doesnt fit anyway because of the heatsink. The only way i coud use it would be as an Y splitter, but that would also mean i would have to use it through an extension cable.
At least now i know everything i need to about this issue.
Thanks guys.
