• 02.10.2026, 20:23
transcendent12
Crushed capacitor on D5 PWM pump?
Samstag, 13. Dezember 2014, 17:57
Hi guys, recently received my order for some aquacomputer stuff: pump, reservoir etc.
The lid wasn't properly on and came off very easily and it seems to have been obstructed by the large capacitor which seems to have taken some damage to the housing. Will this be a problem? Or should I solder a new equivalent capacitor?
mandrix
Sonntag, 14. Dezember 2014, 15:35
You should be OK....
I see a small dent though.....why don't you just try it, it's probably OK. If not it shouldn't be hard to replace if you feel comfortable doing it.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »mandrix« (14. Dezember 2014, 15:37)
Montag, 15. Dezember 2014, 07:29
Normaly it is no problem when the pump is running.
