• 09.10.2026, 18:52
LJHAQUACOM
Pump adapter for D5 pumps for aqualis base with fill level sensor Art: 41095 - dimensions
Sonntag, 18. Januar 2015, 16:30
Hi Guys, do any of you know the dimensions of this unit, in particular how big the metal support bracket is and how far the pump adaptor sticks out once mounted. I'd like to fit two of these units side by side but need to know the dimensions before I invest.
Thnaks, LJ
Sonntag, 18. Januar 2015, 23:48
I don't have this item, but I believe the only difference between the 41094 & 41095 is that the 41095 has the fill sensor built in.
If no one comes up with specific numbers for you, FrozenCPU sells the 41094 and includes some pictures of it assembled that should give an idea of size.
LJHAQUACOM
Montag, 19. Januar 2015, 15:49
Thanks InfoSeeker.
I could calculate the size of the bracket if I had a
reference point. The problem is that the pump top sizes aren't quoted anywhere
either. I assume around 85mm square [to fit the 450ml Res] but I can't tell
how big the bracket fasteners are in width or how far they push the pump top away
from the case. Bracket width is key if I
wish to mount side by side.
LJ
