• 08.10.2026, 09:46
geok1ng
G34 4p build, watercooling checklist help needed
Mittwoch, 28. Januar 2015, 18:18
i apologize for not using German, but i would rather write in English than trust a translator for my first post.
i am building a quad socket opteron G34 system and decided to use the Kryos Delrin G34, among other things because A.C. was th only place i could find a set of 4 waterblocks in stock.
but this block comes without connectors, so i am in the dark form tube sizings, IDs, ODs.
The case is an aerocool strike x st, which is a clone of Xygmatek Elysium, Enermax Fulmo GT and Rosewill Blackhawk Ultra.
i have space for 360mm and 240mm rads.
what i would like to have:
2x 240mm THICK rads
dual pumps for redundancy
single reservoir
some form of leak detection either inline or inside the reservoir
above all i want nozzles and rads that are 200% compatible with the waterblocks, i had problems before with corrosion because of incompatible metals in the loop, nothing chrome plated, ever. i am OK with silver nozzles if that is what it takes.
i ask for help in making a complete list of everything i will need for this build, preferably using A.C. shop for more aquadrops, but i can use frozencpu or performancepcs if necessary.
RE: G34 4p build, watercooling checklist help needed
Mittwoch, 28. Januar 2015, 22:44
2x 240mm THICK rads
single reservoir
Quoted from your llink, near the bottom:
Please note:
G 1/4 connection threads, please order fittings suitable for your hose system separately.
Since the block comes with G1/4 ports you can use any tubing size/method that has G1/4 fittings available.
There are various fittings at the bottom of the link that will work depending on your preferences.
If the fittings you choose are nickle plated you should not have cross metal corrosion issues.
Most all items available in the AC shop are also available on both sites you mentioned, but if you shop AC be sure to have only 1 shipment as their shipping cost is 34.90 Euro, without regard to size or weight of the shipment.
