Du bist nicht angemeldet.
Bytales
And the Relay
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »EnigmaG« (31. Januar 2015, 01:07)
Bytales
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Bytales« (31. Januar 2015, 02:22)
Bytales
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Bytales« (31. Januar 2015, 11:34)
This is not a Relay, is only a Connector, you cut the long green wire (ATX PS_ON# cable) and connect it with the opener(AE5 Relay Pin 2&3 AE6 1&3). If the relay is excited (is this right? In german it is "erregt") it cuts the green wire and shutting down.
Bytales
If you need StandBy-Power at rock bottom Power-on-level (I do´t knowe why) you have to connect the purple wire too on of the red dots and the black to the black (Power or Usb), apart from that do´t connect the 2 Pin.
I do not need Stand By Power, I believe AquaAero doesnt need Stand By power, i believe it is somehow always on. But i could wire it to get Stand By Power as well, since i am building my own wires.
Doesnt it matter to which slot on the connector the green wire goes ?
Should i understand that for this feature to work one has to wire only the green wire ?
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »EnigmaG« (31. Januar 2015, 13:19)
Bytales
So green wire from PSU-Connector end goes to Pin 3 (common connector)
ANd green wire from Motherboard END Connector goes to Pin 1 (normally connected), and in this Configuration the PC should power.
If the AquaAero decides to cut the power, and the wires remain connected as they are (nobody plugs the wire, they remain as they are), when i start the PC fresh, will it start ?
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »EnigmaG« (31. Januar 2015, 13:40)
avictord
I have made the wiring that is suppose to come into aquaero, as seen here, thats the blue wire.
The restofthe white wire is further sleeved, i hope it works.
PS: THe power on wire is slot 9 from the picture, not 3/4 as depicted in the photo.
