• 12.11.2026, 18:30
sircody01
Which device should I select?
Dienstag, 10. März 2015, 17:19
I just setup this D5 pump adapter with this reservoir. Now I'm configuring the fill level sensor. Can anyone guide me on which device I should select (see attached screen shot) for proper operation? There are multiple selections and I can't tell which one is the right one.
»sircody01« hat folgendes Bild angehängt:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »sircody01« (10. März 2015, 19:35)
Dienstag, 10. März 2015, 20:13
At the end of the Pump Adapter Manual it says:
Fill level sensor (art. no. 41095 only)
Please refer to the manual “mps”. The sensor installed into the pump adapter is a “mps
pressure ∆40“. Install a pressure equalizing membrane into the top of the reservoir.
So select the ∆40 you have highlighted in your image.
EDIT: be sure to instal the Pressure equalisation membrane mentioned into one of the top ports of the reservoir, or the results will be incorrect.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (10. März 2015, 20:28)
sircody01
Dienstag, 10. März 2015, 22:54
Ah I see it now. Thank you for pointing out what I overlooked.
Thank you for the warning about the membrane. It is installed as stated.
